New Home Theater Set up
JTodd
JTodd Posts: 20
edited April 2014 in Speakers
Hey guys! Setting up an home theater for my dad and wanted to get some other opinions before I pulled the trigger. He want to keep it simple so I came up with the following:
Harman Kardon AVR 1650 5.1 95 wpc
Logitech Harmony One or 900
Fronts RTi8's
Center CSi5
Surrounds RTi'8s
Sub ???
Anybody have any input on which sub I should use?
Does anyone have any experience with the logitech one or 900? Is there any better options out there?
In general is there anything I should change out to improve the system?
Thank for the help guys!!
  • Syndil
    Syndil Posts: 1,582
    edited January 2012
    If you're wanting to save money on the remote, check out the Monster AVL300. I have one and love it. RF capable with an RF-controlled IR repeater included. Also capable of controlling Z-Wave lighting. Arguably not as sexy as a Logitech, but definitely get more bang for the buck.
  • argylesox
    argylesox Posts: 48
    edited January 2012
    Guess I'll put in a few cents for Logitech. We own the 650 which replaces up to 5 remotes and it is available for under $50. Had great support from Logitech getting it programmed. It uses standard AA batteries and it seems to be of fairly robust build. Oh, and the silver front doesn't show fingerprints like most standard black or gloss black remotes.
  • B Run
    B Run Posts: 1,887
    edited January 2012
    +1 on the Logitech 650, I have one and just ordered another one yesterday. I've been very happy with it and it does everything I need it to, hard to beat for $49.99.
  • Syndil
    Syndil Posts: 1,582
    edited January 2012
    650 isn't bad, but the AVL300 does way more and can be found for only $70 on Amazon. Much thinner than the 650, plus comes with its own rechargeable battery, a charging dock, and the Unilink IR repeater. Like the Unilink the best, I think. Means I never have to aim the remote.
  • michael1947
    michael1947 Posts: 774
    edited January 2012
    I think we are wise to try and use our factory original remotes, especially for the AVR. Combo remotes usually cannot perform all functions of the factory remote and if so then the multiplicity of functions needed to affect the function can easily be forgotten...push one wrong combination of buttons in the dark and you launch an application that takes forever to get out of. Another benefit of using the individual remotes is that you will save many dollars on the purchase of the Harmony and your gear will be worth more when you sell it because you will still have the factory remote. Just my 2 cents worth.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited January 2012
    PSW-505 gets lots of respect for the price. Why towers for surrounds? FXi speaks are wonderful, as long as the layout is conducive to mounting them in the right places.
  • mdaudioguy
    edited January 2012
    OEM AVR remotes are great for setup. After that, they get put away. My Harmony 1's do all I need them to. Never had a problem such as you describe.
  • Syndil
    Syndil Posts: 1,582
    edited January 2012
    Those problems no longer exist with modern programmable remotes with macros. Sure, hang on to the original for resale, but a Harmony or AVL300 is so much easier to use than juggling the originals around. Press one button to watch TV, everything is powered on and automatically switched to the correct input. Press another to watch a movie, etc. One button and done.
  • FrayDog
    FrayDog Posts: 36
    edited April 2014
    I love my Logitech Harmony one remote! have 4 different actions on it.
    1. Watch a movie, which turns on the tv, sets it to HDMI 1, Turns on the receiver and turns it to HDMI 1, Turns on the bluray player.
    2. Watch TV,... turns on tv to hdmi 1, turns on the direct tv box, and turns on the receiver to hdmi 2.
    3. Play Xbox 360, Which is really cool! Turns on tv.... turns on receiver hdmi 3, turns on my xbox 360! The remote is also a controller to the xbox!
    4. Listen to music, turns on the tv, receiver and bluray player... i stream right from my computer...
    but its all one button to start watching or playing... and one button again to turn it all off again... best investment i made, and no more batteries... charging dock!
    Pioneer Elite VSX-82TXS
    Sony bdp-s5100
    Klipsch RW12-D
    Polk Monitor 75T
    Polk CSI30
    Polk RT15
    Polk M20
