construction of the sl200 tweet
DracoAmericanus
DracoAmericanus Posts: 112
edited January 2012 in Vintage Speakers
I have just a general question on the SL2000 tweets, that black mass in the middle, from what i can tell it is a felt pad on the inside of the dome? is this correct? and when these some times fail is it because the felt pad shifts and slides down? , this is on the inside of the dome, not a pad on the outside? wondering if i am on the right track?
There is no cure....
Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
8mm, 7.62x39mm
Post edited by DracoAmericanus on
    pitdogg2 Posts: 27,310
    edited January 2012
    yes there is felt behind the dome. Felt slipping would not fail the tweeter if the felt slipped it may be that the pole piece glue has failed and pinched the voice coil.
