have a polk psw10 dont know how to connect to sony bdve580
Albertmiranda92
i am new to this
Hello Albertmiranda92,
I looked at the quick start guide Sony provides for your unit and it seems the only outputs are the ones that go to the speakers. Since there is a wireless subwoofer that would mean the signal going to the speakers is probably filtered. Therefore you couldn't use the speaker signal to the PSW10, there isn't any bass information for the sub to play. The Sony subwoofer is a wireless connection which doesn't work for the Polk sub. I'm afraid there doesn't seem to be a way of connecting an external sub, sorry.
Regards, Ken
