Where to place the 'better' interconnect. SB -> Pre? or Pre -> Amp?
PrazVT
PrazVT Posts: 1,607
Right now, system is as such:
SB Touch -> DacMagic is using Signal Silver digital coax
DacMagic -> Pre is using Signal Silver ICs
Pre -> Amp is using Signal Analog 2 ICs (5 of 'em)
Speaker wire is Signal Ultra bi-amp.
I have two things on their way right now...
The Pangea P-100 PSU upgrade for the Dacmagic, and a pair of Kimber Hero ICs. Just one pair b/c I couldn't find any on Audiogon and that's all I could stomach $$-wise after the recent speaker purchase.
My gut says place the Heros from DAC -> Pre since that's where the initial signal's coming from. What do you guys think?
- Praz.
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
  • thsmith
    thsmith Posts: 6,082
    edited January 2012
    I find sources benefit more with good cables than pre to amp, so I agree use them on the Dac to Pre.
    heiney9 Posts: 25,724
    edited January 2012
    PrazVT wrote: »
    - Praz.
    thsmith wrote: »
    I agree. When I had just one set of MIT Shotguns and one set of MIT Terminator II's, I put the Shotguns from the dac to pre. Now I have another set of Shotguns to replace the T2's from the pre to amp.
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2012
    Thanks for the input / confirmation guys.
    H9 yah, I plan to add another pair to the pre -> amp chain in another month (for the mains), but to start with wanted to make the best use of the first pair.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • brgman
    brgman Posts: 2,859
    edited January 2012
    I asked this exact question of Joe at MIT some time ago and he was pretty clear that the best IC goes at the source first and downstream from there.
    I’M OFFENDED!!!!
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2012
    Good to know!
    Speaking of MIT ... how are the Shotgun S3s? I read they're warm as far as speaker cables go. Worth the $$ (used of course)?
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2012
    'nuff said I guess :wink:
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
