Projector question...
asah2135
asah2135 Posts: 9
edited January 2012 in Speakers
I know this isn't about speakers, but figured i'd get good feedback here. The installers for my home theater are recommending the Epson Power Lite Pro Cinema 6010.
Reviews look good, but how do you know the quality if you can't see one in person? Have not been able to find a showroom with one of these installed.
Anyone have any thoughts or experience with this projector?
Thank you for all opinions.
Post edited by asah2135 on
  • Drenis
    Drenis Posts: 2,871
    edited January 2012
    This should be in the "Electronics" section. Not sure how you couldn't have associated the two.
  • asah2135
    asah2135 Posts: 9
    edited January 2012
    Apparently, I am a dumbass.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2012
    Avoid that epson and get something better and more current if funds allow
  • PSOVLSK
    PSOVLSK Posts: 5,400
    edited January 2012
    asah2135 wrote: »
    Now that's funny.
    I currently have an Epson that I've been very happy with, but I'm not familiar with the model you're looking at.
    Hopefully Sherardp will chime in because he knows projectors and will give you some good advice and recommendations.
  • polkfarmboy
    edited January 2012
    PSOVLSK wrote: »
    Now that's funny.
    I think he means the epson 6100 and its not a very good projector and it wont be a pro version either as they dont come in that model series
  • PSOVLSK
    edited January 2012
    Or it's possible he means the Epson Pro Cinema 6010 as he clearly stated in the OP.
    http://www.projectorcentral.com/Epson-PowerLite_Pro_Cinema_6010.htm
  • polkfarmboy
    edited January 2012
    PSOVLSK wrote: »
    I would not have thought so but your right I had the 5010 stuck in my head . If thats the choice the op is going to go with then maybe you should go to the AVS thread as I keep hearing about issues with the focus of that particular model. There is a uniformity sharpness problem everyone is having especialy when ceiling mounting upside down. Most users are shelf mounting it right way up to try tame the problem. Also the 3d is reported to have really bad flickering and all the LCD's this year have been plagued by ghosting. The only way to do 3D properly is DLP and they dont have good contrast. Another thing to consider is you cant have frame interpolation or the dynamic iris engaged during 3D and it costs a good deal more than the 5010
    If good blacks and 3D are important then only the Sony VPL-HW30AES can do both and to achieve this you gotta buy the monster vision glasses to near eliminate the ghosting. Every other projector was a near failure for 3D this year and not one machine can do everything right
