How to replace rca cables on turntable, pioneer pl 100
EDUBAG
Hello guys,
just like the title says i would like to upgrade the cables of my turntable with something better assuming that it will result in better sound. I have seen some people modifying turntables and adapting them to be able to use any kind of rca cable (without ground cable). Changing the cables for a pair of rca female plugs.
Is this worth it, soundwise? Is this easy?
Please advice,
regards,
eduardo
Please advice,
regards,
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
IMHO it would be worth it if you use super high quality wire and RCA connectors. With care and planning shouldn't be that difficult. If it were me I'd use small gauge, soft annealed high purity sold silver wire with teflon insulation."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
