Sub enclosure, ported or sealed? Home build.
phil65
phil65 Posts: 24
edited January 2012 in Car Audio & Electronics
I am planning on building a sub enclosure for a MM1040, should I go sealed or ported? Seems to me that building a sealed enclosure is easier but less efficient. I plan on putting the sub under my 02 sierra's rear seat, so I may have to get creative to fit it with only about 7" of space from the floor to the seat, foot and a half or so wide and maybe a foot long (sorry for not having exact dimensions at the moment). Its going to be powered with a pa880 unless any of you have any suggestions for an amp in the same price range that would work better.
Finally getting around to this build, already have the deck in and the rca's and amp remotes wired and ready to be hooked up.
Post edited by phil65 on
  • arun1963
    arun1963 Posts: 1,797
    edited January 2012
    http://diyaudiocorner.tripod.com/dilemma.htm
    A bit technical, but it gives you the pros and cons of both types oof enclosures. A sealed box will give you tighter bass with better transient response, i.e. a more even response in the range that the sub is playing. The ported will be louder but will have a peak at the tuned frequency and a sharp roll off on either side of that frequency. If space is a constraint then I would look at doing a sealed box.
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2012
    Sealed. Always sealed. Ported will give you a little more output but it wont be as good a quality. Sealed designs are also more forgiving of design and build flaws. Plus you tune your ported box to a certain frequency and everything below that frequency drops in output pretty quick.
    So if you want the most "musical" bass, go sealed. If you want the loudest noise, go ported.
  • pentoncm
    pentoncm Posts: 379
    edited January 2012
    Sealed is easier to blend with your mids. Gives you an even bass response. Ported will be really loud on certain songs and then it will sound like the sub isn't playing on others.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  • phil65
    phil65 Posts: 24
    edited January 2012
    Sealed it is, thanks guys
    Gonna be running 12 guage wire to the sub from the pa880. 14 guage wire from the speaker amp (pa 250.2) to mm6501's
    relocating tweeters from the middle door panel to the panel that covers the bolts for the mirrors. Using a 4 guage power wire from the battery then splitting to each amp (fuses at the battery then fuses at the splitter). Does all this sound correct?
  • MacLeod
    edited January 2012
    Yup. 14 gauge would work for the sub too. 12 is a little much unless you're running 1000+ watts.
  • phil65
    phil65 Posts: 24
    edited January 2012
    well that makes it even easier then, ill just grab a bundle of 14 guage and go to town on it:cheesygrin:!
