Atrium 45 Outdoor Speakers
Dave Erickson
I have a pair of 8-10 year old Atrium 45 Outdoor speakers that both stopped working at the same time. I disconnected both of them and hooked them up to another amp and they both still don't work. I can't even get static. I'm thinking it's time to throw them out but I can't fathom why both of them failed at once. Too coincidental. Also, physically the speakers look great. I can't bring myself to trash them. I did have them outside under a deck but it was not a totally dry environment. Just mostly dry. They did fine there for several years. I even took them in during the winter so 5-6 months a year they were not exposed to the elements. I did pressure wash the house and instead of taking the speakers down I wrapped them in plastic bags. It was after that they ceased working. It's now been about a year since they stopped working and I have had the speakers on a shelf in the garage ever since. I am really having a hard time admitting they are garbage. Does anyone have any ideas? Could there have been a power surge that cause this? I do have inside speakers connected to the same amp and they are fine. I also hooked up other speakers to the same speaker wires the outdoor speakers were on and those speakers worked. Thanks for any help!
Post edited by Dave Erickson on
Hi Dave,
Thanks for joining us on the forum. Do you happen to have a volt-ohm meter to measure the DC resistance of the speaker? If you do set the meter to resistance and put a probe in each speaker binding post.
Regards, Ken -
I don't have a meter but I think a friend does. I'll try it. Thanks.
