Need some logo design help
ryanjoachim
edited January 2012 in The Clubhouse
I'm building a website for my local volunteer group (Jaycees).
I can handle the technical aspect of building a website, but when it comes to anything design-related I draw a blank.
I need a logo that is around the same length of the menu bar for the forums (Below the Polk logo), but twice the width, and I need it to be transparent or colored to match the background of my page (#333333).
The logo should say "McMinnville Jaycees", or something similar to that (abbreviations, fancy stuff, etc is fine).
Anyone here have any experience in photoshop or something similar?
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • ryanjoachim
    edited January 2012
    In case anyone is willing to help out, here is where you can see the basic template I'm using.
    http://www.wix.com/ryanjoachim/JayceesRefresh
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • kevhed72
    edited January 2012
    You probably want the roll-over tabs on the pages something different than the HOME tab. Basically, have a tab design for the page you are currently on, a different design for the rollover-tab, and then a third design for the tabs that are "off". (ie you dont want PROJECTS to look the same as HOME when you roll-over PROJECTS).
    I have spent endless hours trying to get the menu bar on my departments website / overall design just right. Website design - doing it right - is really an art-form of sorts. Photoshop is what I use to build images versus just typing within Dreamweaver...if this make sense.
  • Gadabout
    edited January 2012
    I'm sure there are a few here that could help. It would help if you knew exactly what size you wanted the logo to be (in pixels), so it can be properly scaled. If your not sure what size you want, put up any image and use the width & height information to change the dimensions till you get the size your after.
    foo_logo.jpg" width="400" height="100" alt="logo image - size test" title="" border="0">   Once you get the size, I'm sure someone can make something for you, with a transparent background that might suit your needs.  Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • ryanjoachim
    edited January 2012
    The logo needs to be 252x961 (height-width).
    Kev - I assume you mean so that people know which tab they are in by the effect that tab has?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
