Stereo L/R audio over Cat5/6
Serendipity
Just came back from Home Depot and saw that Leviton has a new wall plate system that allows you to carry a stereo L/R audio signal over an Ethernet (Cat5/5e/6) network cable. It was really inexpensive (under $10) so I picked one up. :cool:
The product is called QuickPort, here is some info on it:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=10745&minisite=10026
There are other products in this series that allow you to carry a Composite, Component, or VGA video signal over an Ethernet cable. I saw that the Composite video one was also under $10.
Has anyone used this type of jack before? It's got a pair of red/white RCA's on one end and a punch-down for the Ethernet cable on the back. So it basically carries your audio signal over the Ethernet cable. :cool:
I am going to use these for a subwoofer.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
If the cat5 isn't microstrand six-9's copper flatwire, there are likely be some here that will hate it
i kid.
but that sounds interesting and look forward to your findings.design is where science and art break even. -
The unequal twist of the four different pairs will help you get away with running unbalanced audio on Cat. But it's really not the greatest idea. Likely work ok, but watch for crosstalk.
However, for balanced, it's about perfect! You can also run AES/EBU over cat. Both balanced analog and AES can go very long distances on Cat very well (not in the same run).
But the original design company that they "borrowed" this idea from. recommends against running unbalanced analog.
CJA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
I i've Cat6 for my surrounds for a few years now and they sound great. However I wouldn't think of using them from my L,R and center.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut -
You mean Cat6 for speaker wire?
Or for going from the pre to the amp using a QuickPort adapter?polkaudio RT35 Bookshelves
CJ
I was going to mention crosstalk as well. I would worry that info from one source would bleed into another. -
My subwoofer is connected via the LFE connection. As a result I will be only using the red (Right channel) jack, and only half the pairs of the Cat6.polkaudio RT35 Bookshelves
