Either A7's or A9's?
Dengnath
Dengnath Posts: 9
First, I have purchased 2 - Parasound hca-1000a's
Each one puts out 125w x 2
or 400w mono
I want to purchase either A7's or A9's depending on the recommended set up.
A) Would I be better of buying either set of speakers and running a single amp to each in mono mode?
B) Would I be better off using one amp to power the bottoms and one amp to power the tops?
Thanks for the help!
    Toolfan66 Posts: 18,399
    edited January 2012
    Get the N9NE's hook them up both ways and what sounds best to you keep that set up.
  • Dengnath
    Dengnath Posts: 9
    edited January 2012
    Ok my question about that is am i safe sending 125w to the top and 125 w to the bottom of each speaker.... i just don't know what the limit to each section is?
    edited January 2012
    You will be fine.. Just make sure you pull the jumpers.
  • 62caddy
    62caddy Posts: 137
    edited January 2012
    Won't an external crossover be necessary?
    Main:
    McIntosh: MC 2155, MC 2125(x2), MR 80, C 32, MQ 101; Snell J7; Polk: RTiA7, RTiA9;
    Pioneer PL-518; A/T 440 MLa; Yamaha CD
    Vintage:
    McIntosh: MX110Z, MC 2505, MC 240, Thorens TD 145; Shure V15III; Altec 14, Boston T1000; Yamaha CDX 393 CD; Yamaha Cass
  • Dengnath
    Dengnath Posts: 9
    edited January 2012
    Is it really worth the extra 500 bucks for the A9's?
  • BitenAgain
    BitenAgain Posts: 15
    edited January 2012
    Newegg just had the A9 Cherry last weekend for $499 each. I got the black ones at christmas for the same price. Set up an price watch on the A9';s on there and be patient.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2012
    ^Good to know... The differential does shrink from MSRP levels.
    Dengnath wrote: »
    First, I have purchased 2 - Parasound hca-1000a's Each one puts out 125w x 2 or 400w mono...
    First, welcome...
    Second, are you going 2-ch for music or moving on to an HT?
    - If 2-ch, I'd consider the 9's, but none of our opinions are a substitute for you getting your ears on them.
    - For HT, with a sub to do the deep stuff, I'd lean towards the 7's.
    Third, add vertical bi-amping to the mix as well. Gives you a third option to your A (bridging) and B (horizontal bi-amping) options to check out as Larry (Toolfan) suggested.
    62caddy wrote: »
    At the risk of causing a major derail... No... An external, or active, X-over is never "necessary". Some prefer it; some hear an improvement; some claim it is the only "true bi-amping". But it's not necessary.
    More later,
    Tour...
    Vox Copuli
