KarmonKardon Signature 2.1 5 channel amp
MillerLiteScott
MillerLiteScott Posts: 2,564
edited September 2012 in For Sale (FS) Classifieds
For Sale
HarmonKardon Signature 2.1 Multi-channel Amplifier
Please find my HarmonKardon 5 channel amp that I have used in my basement home theater in a non smoking and pet free environment. I would give it a 8 out of 10 on the Audiogon scale mostly for its age and that I am the second owner. It has a minor scratch on the very back, center of the cover. As you can see from the pictures it has a large toroidal transformer, 10 12,000 uF caps and a huge aluminum heat sink. I have the original packaging and manual.
Highlights from the HK manual
5X100 watts at 8 ohms 20Hz-20KHz <0.03 % THD ALL channels driven.
5X150 watts at 4 ohms 20Hz-20KHz <0.03 % THD ALL channels driven.
High Current capability +/- 100 Amps
Crosstalk < - 87dBr between any two channels at maximum output
Negative Feedback < 25dB
Dimensions (H X W X D) 17 ? X 7 ? X15 ?
Weight 47 lbs
Please read the reviews of this amp online. It is a beast of an amp and will take your HT up a notch or two with more control over your speakers as compared to a similarly power rated or even higher powered AVR. Dynamics and detail will be very apparent with the addition of this amp. Amp has a low volt trigger so that it can be turned on by another piece of gear which is how I used it in my set up. 75 cents per watt at 8 oHms. :)
$400.00 firm United States Postal Money Order plus actual Shipping. Local pickups are also welcome.
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
