How to get Dolby TrueHD on a PC
WagBoss
WagBoss Posts: 108
edited January 2012 in Music & Movies
I can only seem to output dolby digital from my pc to my receiver. I want to play my blurays in dolby truehd, my receiver is capable of it and my video card is a gtx 460, which can output dolby truehd. any suggestions? what bluray player should I use? I have tried powerdvd11 ultra
Post edited by WagBoss on
  • Syndil
    Syndil Posts: 1,582
    edited January 2012
    Are you running Windows 7? Only works in Windows 7.
  • praedet
    praedet Posts: 314
    edited January 2012
    Are you using an HDMI cable?
    HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
    Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
    2 APC H-15s and a Panamax 5400 for good measure ;)
    Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
    VR3 Posts: 29,658
    edited January 2012
    I have the same issue...
    Have not yet resolved this but I will say PowerDVD II sounds a hell of alot better than Coral WINDVD
  • WagBoss
    WagBoss Posts: 108
    edited January 2012
    figured it out. updated powerdvd 11 and was able to select uncompressed hd audio as output, still wouldnt' work. tried a 1.4 hdmi instead of my unknown type, still didnt work. then I learned I have to go to the blu-ray settings menu on the disk and change language from english to english truehd and then it worked :D
