Mit cvt2
acmf74
acmf74 Posts: 936
edited June 2012 in 2 Channel Audio
Has anyone have any experience with this interconnect?
Post edited by acmf74 on
    heiney9 Posts: 25,221
    edited January 2012
  • Drenis
    Drenis Posts: 2,871
    edited January 2012
    ^ He asked about CVT2 not CVT1.
    edited January 2012
    Drenis wrote: »
    Pretty much identical unless you are into splitting hairs. I bet most couldn't tell the difference so I think the descriptions provided in the demo program will be very close if not spot on as to what he can expect.
  • acmf74
    acmf74 Posts: 936
    edited January 2012
    Currently my IC's are SC analog 2s and will be getting MIT CVT-2 ICs this week. Where should I place the MITs to utilize them the most? Between the CDP/preamp or the preamp/amp?
    F1nut Posts: 50,841
    edited January 2012
    Try both, but keep in mind that MIT cables perform best when all are the same, including speaker cables.
  • fjross
    fjross Posts: 183
    edited January 2012
    I am in a similar situation, I had to cap the budget at speaker and (1) pair of interconnects. Joe from Equess recomended the higher quality cables between the cd and preamp. I'm waiting for the Shotgun 3.3s to arrive early next week.
    Mcintosh MC-501 mono blocks
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    MIT 3.3 Shotgun biwire speaker interface
    MIT 3.3 Shotgun XLR interconnects
    Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
    Polk 3.1 TL's mint/stock (purchased new)
    Polk SDA-2's
  • acmf74
    acmf74 Posts: 936
    edited June 2012
    Zero wrote: »
    Yep. Running a full assortment of CVT-2's at the moment.
    Zero. I'm thinking of doing the same. How do you like them?
