Connecting TSi100 to macbook pro
marvin88
marvin88 Posts: 1
Hello,
I recently acquired a set of TSi100 bookshelf speakers and would like to connect them to my macbook pro laptop. Im looking for a relatively inexpensive and simple setup. I have very little experience with speakers but from some quick google searches it appears I need to buy a receiver to power the speakers. If this is correct, what kind of receiver do I need? Also, would an external sound card work to power the speakers? From some basic research they seem to be much cheaper and simpler than receivers but I'm not sure if one would work for what I need. Are there any other options for what I need?
Any advice or input would be greatly appreciated.
thanks,
Marvin
Post edited by marvin88 on
    edited January 2012
    You need a way to power those speakers and a computer won't do that, hence a receiver. Depending on your needs or future upgrades you may have in mind, many are available at many different price points, new or used, from brands like Pioneer, HK, Onkyo, to name a few.
    Your other option is to buy self powered speakers made for computers.
