Options with Sunfire and Adcom
squeeb
squeeb Posts: 426
edited January 2012 in Electronics
Okay, I can't wait to get home tonight and connect my SDA SRS 2s (pics to follow). Now comes my question; do I,
1) Strap the negatives on my Adcom to make it a common ground and run L/R off the Adcom and other 5 channels on my TGR3?
2) Run all 7 channels on the Sunfire (is it a common ground amp?) and look to sell the Adcom and upgrade to another 2 channel amp? Can the Sunfire run 2 speakers 4 ohm and 5 speakers at 8 ohm when watching movies?
3) Other?
Just working through options so when I get off work I will be ready to roll. Thanks.
7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
Post edited by squeeb on
    nooshinjohn Posts: 25,876
    edited January 2012
    The sunfire will have no trouble doing what you are asking it to do. It is common ground and will be a match made in heaven for the SDA's.
    Congrats and enjoy!
    heiney9 Posts: 25,398
    edited January 2012
    How do you know your 3 channel Adcom is not common ground?
  • squeeb
    squeeb Posts: 426
    edited January 2012
    Larry told me when I was checking into the speakers. I sent an email to Adcom last night to verify (no offense Larry). Do you have a differing opinion?
    I am learning as I go - without blowing anything up. Not that long ago I was buying a HTIB - just plug in the cheap plastic red connector to the corresponding red input on the receiver... :redface:
  • squeeb
    squeeb Posts: 426
    edited January 2012
    Congrats and enjoy!
    I think you gave me a semi!!! I may need to take the afternoon off to get them hooked up. Can't wait.
    edited January 2012
    squeeb wrote: »
    Nope, not all Adcom's are non-common ground so I just wanted to make sure you had a reliable resource for your info.
    Toolfan66 Posts: 17,982
    edited January 2012
    No offense taken. back in the day when I had 2B's (almost 3 years ago first SDA's) I was looking at a 5503 and did call Adcom and they told me it wasn't common ground.
    Call them they should still be there just to give you piece of mind, but as John stated you can use the sunfire as it is common ground.
    edited January 2012
    Toolfan66 wrote: »
    The Sunfire is the only receiver out there I can think of that has the juice needed to get the job done without an external amp IMHO...
    edited January 2012
    any updates there Squeeb... pics perhaps? All this sage advice don't come for free you know.
  • squeeb
    squeeb Posts: 426
    edited January 2012
    Absofrickenlutely! I started a new thread in case people over this one. However, I meant to add a link. Thanks for the reminder and advice.
    Hooked them up last night to the Sunfire and they sound good - not great - but still have a few tweak and placement issues to work through.
    http://www.polkaudio.com/forums/showthread.php?128095-SDA-SRS-2s-Are-Mine
