SDA SRS 2 - Deal or No Deal
squeeb
I am looking at some SDA SRS 2 for sale - $600. They are stock with just the tweeters replaced a couple of years ago. I haven't seen much for sales lately - may be good or not so good. Would they work in place of my RTi12s in HT with my other RTi speakers? I am going to make the strong assumption they will be better in 2-channel.
As always, just looking for some awesome, free advice. Thanks.
http://www.polksda.com/sdasrs2.shtml
7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
Post edited by squeeb on
They will smoke your 12's for 2 channel, and I talked with the guy he will take $500 these are a hard to find set and they are pin/blade as well.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Thanks - you must be the "guy from Denver" he talked to. Glad you may have too many SDAs now. Give some of us newbies a chance to own some. Will it sound good in the HT? Or at least as good as I have now?7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi -
Go Get Them......Now ! You will never (probably) find another set that cheap.
Great Score for $400!!!!!
Congrats Brian, Enjoy!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Thanks - can't wait to get them hooked up. Guess I need to make my Adcom 5503 a common ground first. Is my Sunfire AVR a common ground and would it be "better" to use than the Adcom? Or, will it cause problems having the fronts 4-ohm and the others 8-ohm? I am afraid I just jumped further down the rabbit hole.
He also has a pair of Acoustic Research M6s for sale - possibly down to $200 - if anyone is interested. http://www.classicspeakerpages.net/library/acoustic_research/holographic_series_1990/holographic_series_brochure/holographic_series_brochure.pdf
Sounds like he is going through a divorce and does not want his ex to get them or know the proceeds. I would get them but my wife said she would leave me if I bought another pair of speakers. :sad: I will probably miss her when I am not listening to my speakers!7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
