Fluke Multimeter Wanted!!!
Toolfan66
Can I pick up a good Fluke Multimeter to measure DCR for around $300?? Or another brand that might be just as good? Any model # or link would be great.
Thanks!!
Thanks!!
Post edited by Toolfan66 on
I will link you some things when I get home tonight. Sorry at work to 11pm
Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
eBay man....easily grabbed <300.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Polk F/X500i Rears
Parasound HCA-3500
I'm really fond of my Fluke 88; although it's an older one (current version is 88 Series 5, or V) Had some problems with it a few years ago, which turned out to be flaky test leads--must have a poor internal connection. New test leads instantly eliminated the screwy readings.
List price is astronomical, discount price is within your limit if you buy the meter and test leads but not the rest of the automotive-specific "kit" which includes an inductive spark probe and a temperature probe among other niceties.
This meter is intended to be automotive-intensive; will have a bunch of test capabilities you won't need if you don't plug it into an ignition system. If you're not going to use it for automotive stuff, you could probably spend less for a more suitable unit.
The only way I'd give this one up is if I replaced it with the Series 5.
A nice feature of both my original 88 and (I'm pretty sure) the 88V is the ability to measure low ohms--tenths of an ohm.
http://www.amazon.com/Fluke-88V-Stand-Alone-Multimeter/dp/B001HX9UNC/ref=dp_cp_ob_hi_title_2 -
I picked up an excellent condition Fluke 178 off eb for $160. It still had the protective plastic film over the display, was recently calibrated and came with a nice leather case and leads. There are deals out there.Stan
Main 2ch:
HT:
Other stuff:
I got my Fluke 117 at Sears ($180). They stock a couple Fluke multimeter models that are slightly less expensive, too.cristo
NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
(with Sonicraft/Solen/Mills crossover rebuild) -
Love that company name.
"If it works it's a Fluke."Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
i got one labeled MD73AS3 from matco tools on ebay, it is a fluke and has the same features as i think the 87, but totaly shure but it works well and was 60 bucks, mostly because the odd model number, been my meter for 6 years and works very wellThere is no cure....
Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
8mm, 7.62x39mm -
