LSi9 bi-amping question
Milsivich
Milsivich Posts: 43
This is my setup:
LSi9's
MicroPRO 2000
Parasound Newclassic 2150 amp
Parasound Newclassic 2100 preamp
My question is, should I bi-amp the LSi9's using the speakers A & B outputs on the back of the 2150? I feel like this will effect only the overall sound because I wont be able to control the zones separately, which is in my mind the only reason to bi-amp, but maybe I'm wrong. What do you guys think?
Happy new year!
Post edited by Milsivich on
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2012
    True biamping requires the use of a separate amplifier. What you are describing is simply using the speaker "A" and speaker "B" outputs to drive your speakers. You would need to purchase another Parasound to achieve the effects of true biamping.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    F1nut Posts: 52,022
    edited January 2012
    It's a 2 channel amp and therefore is not capable of bi-amping.
    Here's something you can do to improve the sound, replace the stock jumper bars on your speakers with high quality speaker wire.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2012
    Absolutely replace the stock jumper bars! That will improve the sound. You've got good equipment so focus on things like the jumper bars, getting decent speaker cables and interconnect cables and speaker placement.
    DKG999
