Anyone Familiar With Onyx?
deronb1
deronb1 Posts: 5,021
edited January 2012 in Speakers
Guy on CL has a pair of Strata Minis and a matching center for 600 bones.
http://dayton.craigslist.org/ele/2777289363.html
Post edited by deronb1 on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2012
    I'd pass unless you just want to try something different.
  • jephdood
    jephdood Posts: 1,690
    edited January 2012
    Actually, it's Onix. I once owned a pair of Minis. They are FANTASTIC for music. But they really won't cut it for reference-level HT. I tried it, and the 5.25" on the front looked like it was going to pop out of the front baffle it was moving so much. Also, that center is 'matching' in finish only, really. It was designed for use w/ their Ref speaker line. There was no center made for the Minis. If you're looking for a 2-channel solution, though, they really are great. The only thing I'd be worried about is the amp driving the 10" going out some day and no company to go to anymore for support.
    "I did not slap you. I high-fived your face."
    txcoastal1 Posts: 13,499
    edited January 2012
    I was one of the ones at LSAF that Skip is referencing to, if your primary genre is jazz or classical they work well, my interest in the was to get them cheap at the show. They were played through Melody hybrid integrades.
