SETUP: ONKYO TX-SR607 + SurroundBar 42 + PSWi225
I would like some advice on my receiver and subwoofer setup. I have a SurroundBar mounted on a wall below a 40" Sony Bravia TV. The receiver is a ONKYO TX-SR607 and the subwoofer is the wireless PSWi225.
1. What speaker settings / options do I need to tweak on the receiver? The current settings are:
Front: 100 Hz
Center: 120 Hz
Surround: 120 Hz
LFE: 100 Hz
Level Settings:
Left, Right, Center: Zero
Surround Left and Right: +3.0 dB
Subwoofer: +3.0 dB
2. The receiver instructions show a diagram with a PRE OUT for the subwoofer. Do I want to connect one or two jacks from the provided RCA cable to the receiver and use the LFE input or the L and R jacks on the wireless transmitter? The receiver instructions state that the same signal is output from each jack.
http://63.148.251.135/redirect_service.cfm?type=QuickHookup&file=SN29344959_TX-SR607_QSS_En_web.pdf
3. When I have the subwoofer connected and the power setting in the Auto position, the subwoofer goes into the "Wait State" (red light) even though there is audio coming from the Cable box through the receiver. What determines whether the subwoofer goes into the wait state?
Thanks in advance for any help you can provide.
