Which Subwoofer would be best?
sleepyweasle
I am currently looking to upgrade my system, I have decided to use RC85i's for all 5 of my HT speakers. I will be driving the theater with a Denon 3808CI. My room dimensions are 11 X 16 with the system on one of the 11 foot walls. What I want to do is place 2 subwoofers at the opposite side of the room and on the opposing corners. My budget is 300.00 per sub using the 300.00 credit for buying the RC85i's. I have used this Foum in the past and found it to be extreme helpful, I look foward to hearing from you. Thanks in advance.
PS the equipment list below is from 2004 so none of it is relevant anymore.
Reciever - Onkyo TX 797 (100X6)
Mains - RTi8's (Bi-Wire)
Center - CSi5 (Bi-Wire)
Surrounds - FXi5's
Subwoofer - SVS 20-39+
Moniter - Sony KP-57HW40
DVD #1 - Sony - DVP-985V (400 Disc)
DVD #2 - Panasonic - DVD CP72
CD - Sony - CDP-CX450 (400 Disc)
Sat - Sony SAT - W60 (DirecTv)
VHS - Sony - SLV-N88
Surrounds - FXi5's
Greetings - so your question is which Polk sub to get because you've got a Polk credit of $300?
Or you have $300 in credit that can be used anywhere?
300.00 in polk creditReciever - Onkyo TX 797 (100X6)
Surrounds - FXi5's
VHS - Sony - SLV-N88 -
From your sig - you've already got an SVS 20-39+, which is pretty well regarded.
Are you looking to replace this with two Polk subs?
Yeah I do but I have had to move to a new house and dont have room for it, and yes I wanted to replace it with 2 polk subs or maybe 1 better polk sub.Reciever - Onkyo TX 797 (100X6)
Surrounds - FXi5's
Sleepy... May I suggest this great deal on Polk @ Ebay? It is a refurb but the price is perfect!
http://www.ebay.com/itm/Polk-Audio-DSW-microPRO-3000-10-1200-watt-2400-max-/360419338935?pt=Speakers_Subwoofers&hash=item53eaaaaab7LG 55LH90 | Onkyo TX-NR809 | Emotiva XPA-3 | polkaudio RTi12 | polkaudio CSi5 | JBL ES250P | polkaudio RTi4(4)
"Sound satisfaction is in the ears of the beholder and what that pocketbook bares"
