Ayon CD1 tube player
brgman
brgman Posts: 2,859
edited January 2012 in For Sale (FS) Classifieds
All the info is here with a review.
http://www.6moons.com/audioreviews/ayon/cd1.html
Original box and manual.
$2000
I’M OFFENDED!!!!
Post edited by brgman on
  • NotaSuv
    NotaSuv Posts: 3,871
    edited December 2011
    Ayon apparently uses the same enclosure as that of the Canadian Raysonic Audio CD-168, my highly prized unit. The two players look virtually identical save for the location of control and power buttons and digital display. Otherwise, they both employ the same top-loading, aluminum stabilizer arrangement. Even the acrylic top plate is similar if not indistinguishable. The companies' CD remotes match as well. Even the specs pan out similarly but with some slight/major differences (depending on your viewpoint and concern for specs): both use Solen and Mundorf caps, weigh in at 11kg, use ceramic sockets and C-core transformers and run class A outputs single-ended and balanced. The CD-168 uses a Phillips VAM 1202 transport, produces an output level of 2.3 volts to the Ayon's five volts and maintains an impedance of 110/330 to Ayon's 30/170 (RCA/XLR). The CD-168 uses two Burr Brown PCM 1792 chips while Ayon relies on the Crystal CS 4398 chip. The rub? The CD-1 sells for $4,299 while my trusty Raysonic CD-168 sells for an ever cooler $2,500.
    Enough of the love fest, how does the CD-1 compare to its lookalike, my very own Raysonic CD-168? The players use different tube and chip sets so you already know that while they may look the same, they are going to sound different. Returning to the Rimsky-Korsakov, the Raysonic portrayed the CD's large hall acoustics with similar soundstage characteristics. Ditto for its bass treatment though it was a mite cloudier in that respect. The Raysonic's midrange was more closed-in and less expressive however and when required to reproduce complex passages at higher volumes, it could turn strident by comparison to the Ayon. The Raysonic created more of a 5th-row perspective compared to the Ayon's front-row center perspective. Though its tonality was generally of a similar mien, what the Raysonic really lacked compared to the almost twice as expensive Ayon was that machine's sense of pure, unadulterated emotionalism. The Ayon drinks of the Raysonic's basic ingredients yet produces superior results of creamy liquid goodness. The Raysonic benefits from tube rolling and proper cabling (Shindo interconnects work warm wonders) and within its price range, it's unbeatable but the Ayon gives a more powerful, heart-pounding take on the same music.
    And so, for its sheer musicality, versatility in recreating all forms of music, fleetness of tonality and colors, profound emotionalism and consistently earth-shaking dynamics and extension, I award the Ayon Audio CD-1 my second-ever Blue Moon Award. For $4,299, the Ayon CD-1 is a superb musical CD machine. Fans of both blood and guts showmanship and gentle audio epiphanies avoid this extraordinary player at their own peril.
  • danz1906
    danz1906 Posts: 5,144
    NotaSuv wrote: »
    Looks like two very good Cd players!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • michael1947
    michael1947 Posts: 775
    Very Cooool.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • SteveFord
    SteveFord Posts: 38
    edited January 2012
    Still available?
  • michael1947
    edited January 2012
    Anything that pretty must sound amazing.
