Over the air HD antenna question......
shawn474
shawn474 Posts: 3,052
edited January 2012 in Electronics
OK, so some of you have been following my thread of getting rid of cable and going with an OTA HD antenna and a roku box. My question is this; I have 2 televisions in the house. My downstairs tv gets about 45 channels from the antenna. I have a smaller tv in the bedroom and only get 20 something channels. Should this be? Or does each have a different quality tuner? If so, would an antenna amplifier help?
Thanks for the input,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • Glowrdr
    Glowrdr Posts: 1,103
    edited December 2011
    Are you using a whole house antenna, or a different one at each spot? While I don't doubt there are different quality tuners - I would expect the antenna itself to have a greater impact.
    If you are in fact using a WH intenna - then that shot my theory all to heck.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    mhardy6647 Posts: 34,916
    So... the two sets are both connected to one antenna? If so, how? Via a two-set coupler or an A-B cable switch?
    All things being equal* the difference "must be" in the tuners, I would think.
    * The only other obvious variable would be the cable runs between the coupler/switch and each TV. Maybe a difference in quality/condition in one cable vs. the other is introducing some loss?
    In 75 ohm coax, everything added to the line introduces some loss. Even an "F to F" union has an insertion loss of about 1 dB :-(
    FYI and FWIW, we just stuck one of these out on our old eave-mount rotor. It works pretty well in our deep fringe suburban (nearly rural) location NW of Bahsten. I wish someone still made parabolic UHF reflectors... that would be the ideal antenna for OTA DTV.
    http://www.channelmasterstore.com/Digital_HDTV_Outdoor_TV_Antenna_p/cm-4221hd.htm
  • shawn474
    I am using a whole house antenna. From what I can tell, the difference is this: I have the antenna cable running to a splitter. Antenna cable to the in part of the splitter and outputs go to downstairs tv and master bedroom tv. Here is what I found: The splitter has two outputs - one that is labelled 3.5db and one labelled 7db. The 3.5db goes to the downstairs tv that gets more channels. The 3.5db goes to the upstairs tv. I switched them and the results switched (i then got more channels upstairs and less downstairs). Does this make sense and WTH is the point of having two different outputs on the splitter? Should I just get a cheap-o dual 3.5db splitter? And why would this be the case?
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    so... is there an amplifier in your splitter? i.e., are those numbers gain... or attenuation?
    I'd better bow out; this is something I don't know about, in terms of "modern" hardware :-P
    Sorry.
  • shawn474
    Well it just so happens I had a dual -3.5db splitter in the shed. Hooked it up and all is well again. Each TV gets the same amount of channels. I have no idea why that mattered but it did and the wife is ecstatic after seeing how much money we will save. I politely informed her that no cable in the bedroom probably means less interesting television, which means boredom which means a need to occupy the time which means :eek:
    She was surprisingly OK with my suggestion..............this could work out in more ways than just saving some money!!!!!!:cheesygrin:
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • shawn474
    OK, last question; I SWEAR!!!! Would I be able to hook this up my AVR to get FM radio stations?
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    Most of the modern antennae for DTV won't be sensitive to the FM radio band - it's is between the old VHF Channels 6 and 7, in terms. A VHF/UHF antenna would have some gain in the FM band - as long as there are no FM traps in the antenna or subsequent circuits.
    A dedicated FM Yagi (or log periodic) with a rotator and some altitude is still the best way to go.
    http://www.starkelectronic.com/fm.htm
    (not the cheap crossed dipole at the top of the page...)
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    All good advice here, but will add this a good clean ant amp could help if you're splitting signal since you have an loss by splitting the signal. But on the other hand just splitting 2 way shouldn't harm the signal to greatly, so may try it first before adding ant amp.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2012
    shawn474 wrote: »
    Yes, if you have a good VHF/UHF antenna with FM capability. I am running a Radio Shack VU-XR190 ($159) and it does a great job of picking up DTV and FM stations.
    The splitter you had before with 3.5dB attenuation and 7dB attenuation meant that the TV with 3.5dB will get more signal than the one with -7dB attenuation. So I would suggest looking for a splitter with high bandwidth and equal attenuation here, especially if you are going to add a third device (the AVR's FM tuner) to the equation.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • shawn474
    edited January 2012
    Thanks Alex. The FM tuner isn't a priority at all. I have never had FM tuners in any of my set-ups; and especially if it would degrade any of the signals I am out on using it. I have ordered an amplifier for the HD antenna just to see what benefits it gives. I did experience some pixelation and drop-outs during normal tv watching so hoping that will help.
    Overall, I am not going to miss cable much at all. The only three channels I was missing was AMC (for one show only - The Walking Daead), Discovery and ESPN. Discovery I can get over; ESPN I have figured out a way around it. I am getting a DVI to VGA splitter and running one cable to my computer monitor and one to my television. Then I am able to watch all ESPN programming through my computer on my television. Imagine the money I could have saved if I was smart enough to do this before!!!!!
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    shawn474 wrote: »
    I am no expert at cable but I have had ota since the first ntsc tuner was available in a tv. I have found that inline amps are good for a stronger signal but the blocking and interruption is before the antenna due to weather or whatever so the amp just amps the signal whether it's clear or no. I also found a vast improvement when splitting off to fm for my receiver. More, clearer stations. I would agree it is imperative to have an inline amp if you plan to split more than once.
    Death to Cable! :)
    Too much **** to list....
  • Serendipity
    edited January 2012
    An amplifier boosts everything, both signal and noise, so if you are experiencing interference (such as bad weather causing the signal to break up), the amp may or may not solve such problems. In some cases, it may make the pixellation worse when the signal is marginal. The amp cannot compensate for poor antenna aiming, etc. So as the signal to noise ratio is dependent upon a variety of factors, best thing to do is to try it out and report the results.
  • camp21178
    camp21178 Posts: 273
    edited January 2012
    I have a cheapy directional FM antenna hooked up to a separate tuner and I'm picking up KQRS from the Twin Cities about 90 miles away. I've also had very good luck with a UHF-VHF antenna because FM is between channel 6 and 7 like previously mentioned.
  • haimoc
    haimoc Posts: 1,031
    edited January 2012
    Have you tried a preamp to the antenna? Preamp ensures better signal quality to your TV tuners.
    I have Winegard HD7695P Antenna & AP8700 Preamp.
  • shawn474
    edited January 2012
    haimoc wrote: »
    I have a different antenna. This one. And I just installed the exact same preamp that you have. It definitely improved my reception and decreased the drops and cut-outs of the signal, but didn't eliminate them. I think it may have to do with aiming the antenna better. So I will play around a bit when I have time and see how that affects the signal.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
    pitdogg2 Posts: 26,928
    edited January 2012
    Consider yourself lucky IF you get any FM on that antenna. It's just not made for it.
    you'll need a rotor for best results on the HD side
    I use this one and it will bring in the FM from 75mi away
    http://www.amazon.com/PCT-International-ANCM3671-Channel-Antenna/dp/B0013BTLTG/ref=sr_1_3?s=electronics&ie=UTF8&qid=1325711536&sr=1-3
  • shawn474
    edited January 2012
    I think I will try to go without anything else and see how often the drops happen and such after playing with the direction of the antenna. Eventually I might go with the rotor. Just for kicks, the remote controlled antenna isn't able to be controlled by the harmony is it? And can you program the rotor to change to a deefault location for each channel. For example if channel 2 tower faces NW, when I change to channel 2 would it automatically move to a NW position?
    Thanks again for all the input,
    Shawn
    Nah, I pretty much gave up on the FM reception, mostly because I would never use it. Just thought it would be cool if I could actually have it after going without for so long.
    A rotor huh? This is getting way more involcved and costly then I thought!!!! The point of this was to SAVE money; not to keep spending it!!!!:cheesygrin:
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • haimoc
    haimoc Posts: 1,031
    edited January 2012
    shawn474 wrote: »
    If you have not installed the preamp at the antenna (very closed to the antenna), you might consider to do so. Some people have preamps after 50-100 feet of wiring from the antenna. Preamp should be installed at the antenna output and have it wiring to the house after that.
  • shawn474
    edited January 2012
    haimoc wrote: »
    If you have not installed the preamp at the antenna (very closed to the antenna), you might consider to do so. Some people have preamps after 50-100 feet of wiring from the antenna. Preamp should be installed at the antenna output, and have it wiring to the house after that.
    Yep, that's the way I have. Preamp is wired right at the antenna.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • haimoc
    haimoc Posts: 1,031
    edited January 2012
    It sounds like you have everything right, so I guess fine-tuning with antenna aiming or trying with different tuners to see if you're not losing the channels are the next thing to do. Quality of tuners also affect the result of scanning for the channels, too.
  • shawn474
    edited January 2012
    haimoc wrote: »
    Are you talking about external tuners separate from the built in tuner of the television? Both of my tv's have internal tuners.
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • haimoc
    haimoc Posts: 1,031
    edited January 2012
    I would say all tuners (internal, external or tuners for PCs) and not all TV built-in tuners are the same quality.
  • shawn474
    edited January 2012
    haimoc wrote: »
    Thats my guess too. My downstairs tv is a 46" samsung lcd - nice one. My bedroom tv is a 20" insignia - not so nice. I suspect that the internal tuner is not as good and the reason why it is having a few more hiccups
    Shawn
    Front: Polk LsiM703
    Rear: LSI fx
  • Serendipity
    edited January 2012
    shawn474 wrote: »
    Yes. Some tuners deal with noise better while others need a higher gain in order to even show a picture but once they lock the signal, they are good. If you are having issues with the downstairs TV, try different levels of signal gain as too low or high an input signal (in dB) may cause the tuner to perform worse.
    edited January 2012
    shawn474 wrote: »
    Shawn
    My channelmaster will not change direction when i change the channel. but the new digital rotors can be set up to go to that direction when you punch that number on the rotors remote.
    There are some up front money to be spent BUT like myself I went deep into it 15yrs ago and have not spent a dime since. It's not like you just keep spending good gear will last a long time. (unless it gets smacked by a tree or lightning.
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2012
    shawn474 wrote: »
    Just saw this thread. External Samsung tuners (even 2-3-yr-old DTB-H260F) are very good. I haven't seen a better one than 260F to be honest. Tuner in my G-series Panasonic is also slightly better than the tuner in Sony LCD... So yeah, a lot of them are differnt.
    Quality preamp on the antenna will always help (ChannelMaster or Winegard). And always, always make sure that the antenna is properly grounded, because if the lightning will hit that antenna (as being the highest point of your house) and the house will catch fire, insurance will surely check what caused it.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • m60cs2
    m60cs2 Posts: 38
    edited January 2012
    ViperZ, would they not pay if they found out you didn't ground the antenna?
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2012
    m60cs2 wrote: »
    That's what I tried to say. sorry :)
    B&W CDM1-SE fronts
    B&W CDM-CNT center
