Curious - SDA-CRS+ Cabinets
audiocr381ve
audiocr381ve Posts: 2,588
edited January 2012 in Vintage Speakers
Has anyone ever built better SDA-CRS+ cabinets? I mean, it's not the best looking cab (so says my wife), and it's literally just a box. It would probably look better with some rounded edges and a new grille. I don't know, I'm not a carpenter at all but it seems like it would be incredibly easy given this speakers design.
Post edited by audiocr381ve on
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2012
    I have built cabs to replace monitor series speakers in the past and they sounded just as good and looked tons better.
    As long as you stick to the internal dimensions along with speaker and PR placement it should be fine.
    F1nut Posts: 50,761
    edited January 2012
    This should be good.
  • evhudsons
    evhudsons Posts: 1,175
    edited January 2012
    So keep the internal dimensions the same? Wouldnt it just be easier to build a shell around it? I'm going to re-veneer mine. I've seen some beautiful works of art on this site with crs+.
  • codyc1ark
    codyc1ark Posts: 2,532
    edited January 2012
    I'm pretty sure that this has been discussed before here, and I also believe that you would have to have the specs for the driver cutouts, IIRC they have a slight angle to them, at least the SDA driver. Maybe someone with more knowledge will chime inn, as I'm unsure if this is possible...
    pitdogg2 Posts: 25,695
    edited January 2012
    I concur
    Toolfan66 Posts: 17,337
    edited January 2012
    +100000
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • audiocr381ve
    edited January 2012
    Joe08867 wrote: »
    Cool, glad to hear someone else has tried it and had success. I knew it couldn't be harder than it looked. I've taken the speakers apart about a thousand times and keep thinking to myself how easy it would be to build new, better looking cabs myself. When I was into car audio as a teenager, I always built my own sub enclosures out of 3/4" MDF to the correct airspace required for the sub (using some old software that I can't recall the name of)
    I may take a crack at it!
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2012
    How so?
    More later,
    Tour...
    Vox Copuli
