NEED HELP!! Hpsa500 in protection mode!
polkanddie
polkanddie Posts: 224
edited December 2011 in Electronics
I had some problems with my breakers messing up and I feel it had something to do with this amp being stuck In protection mode. It's on the work bench right now and the circuits boards have no burns on them so I feel it maybe just a certain component failing. If anyone has any experience working on amps it would be awesome if you could walk me through where I should start. I have my multimeter ready! Thanks!
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
Post edited by polkanddie on
  • Serendipity
    Serendipity Posts: 6,975
    Since you have a multimeter, what's the rail voltage look like?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Serendipity
    Also, check if any of the output transistors are shorted.
