Balanced vs Unbalanced IC's
acmf74
acmf74 Posts: 937
Currently my whole system CDP,AVR and AMP are connected by unbalanced IC's
I'm am planning to incorporate a Pre-Amp into the rig.
My question is the AMP and Pre-Amp has Balanced inputs. Would it be beneficial if I go with a balanced IC between the AMP and Pre-Amp while the rest of the system is unbalanced?
The run will only be about 4 feet.
Thanks!
  • CoolJazz
    CoolJazz Posts: 573
    edited December 2011
    One small difference that could come into play is that with a balanced connection between the two, you'd be eliminating possible current flow between the two via sharing grounds that comes with the unbalanced connection. Mixing current loops would be not possible when going with the balanced.
    That source equipment is unbalanced has nothing to do with the decision about the pre to amp connection.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
