Speaker Wire Help
tmartin
Hi there,
My basement rear surrounds had been pre-wired from a renovation done a few years ago. I'm a newbie to HT setups.
Unfortunately I think contractors used a cheap a 18 AWG wire and now I've been running my setup through my receiver in this manner:
Receiver connect using 12 AWG --> into wall/ceiling with 18 AWG --> out to 16 AWG connect to rear surrounds
Sound is alright. Can anyone tell me if this is a problem/improve? Also, would you recommend using banana plugs and wall plates for connections or is wrapping copper around posts and making connections with electrical marretts enough?
Thanks ALOT!
TM
Sony KDL-60NX810
Pioneer VSX-1020-K
Polk TSi500 (2)
Polk CS10
Polk FXi A4 (2)
Polk PSW505
Logitech Harmony One
Thanks ALOT!
TM
Sony KDL-60NX810
Pioneer VSX-1020-K
Polk TSi500 (2)
Polk CS10
Polk FXi A4 (2)
Polk PSW505
Post edited by tmartin on
Hi, and welcome to the Club. For surrounds, 18 ga is probably enough since they don't typically get a lot of watts. 16 ga would have been better, but a lot of it also depends on how long the run is. Basically, the longer the run, the larger gauge needed. 18 is probably fine for anything up to around 20 ft. or so for surrounds. Other than for looks, wire nuts are probably fine. But if the wire is really cheap, does it look like it's turning green inside the housing? If it does, it needs to be replaced.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Thanks quad for the welcoming.
I have the same scenario. Should I replace the wire for a better sound ? Some of my speaker runs are 50' +
Personally, for a run that long, and if it's possible and feasible to do so, I'd upgrade the wire. Distance is a factor. Check out Crutchfield's guidance: http://www.crutchfield.com/S-GSFMxOkvGDF/learn/learningcenter/home/speakers_wire.htmlcowtrimmer wrote: »I have the same scenario. Should I replace the wire for a better sound ? Some of my speaker runs are 50' +
Btw, welcome to Club Polk!
Thanks for the welcome and the article links. Its very much appreciated.
