Comparing rti A1, rti A3, tsi 100 and tsi 200
WagBoss
WagBoss Posts: 108
edited December 2011 in Speakers
How do these bookshelf speakers compare in terms of sound quality and sound quality for the price? Are the more expensive tsi 200 worth the upgrade over the other 3?
Post edited by WagBoss on
  • rebuy
    rebuy Posts: 695
    The TSI are good speakers and the RTI are better. GO to the product pages here and it will tell you more about the different series.
  • Topper
    Topper Posts: 403
    If you can fit the RTis into your budget, definitely go with them. RTi A3 is (not surprisingly) my favorite from the four listed and well worth the extra dinero.
  • WagBoss
    WagBoss Posts: 108
    Ok thanks guys.
  • WagBoss
    WagBoss Posts: 108
    Does anyone else have any opinions on comparing tsi200 to rti a3 as front speakers?
  • chumlie
    chumlie Posts: 8,658
    Get the rti a3's over the tsi200's. You'll kick yourself if you don't. And end up with the rti's eventually. Thats another opinion for ya.
  • larry777
    larry777 Posts: 480
    I would also pick the RTi line over the TSi's. I would then pick the RTiA3 over the RTiA1's if the budget allowed.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
    gudnoyez Posts: 8,156
    I dont think the Tsi 200's are the more expensive of the 3 mentioned. The Rti'a3 are the more expensive of the ones you mentioned, and with good reason the A3,s are the better one of the ones you are considering
