How to determine DSW Pro 660 volume level?
Hannzz
Hannzz Posts: 34
Hi Guys: What is the best way to determine volume level of DSW Pro 660 since it does not have a vol knob. thanks
Post edited by Hannzz on
  • thsmith
    thsmith Posts: 6,082
    edited December 2011
    Sound pressure meter then use avr level adjustment to match with mains.
  • Glowrdr
    Glowrdr Posts: 1,103
    What do you mean by determine the volume level? If you just mean the volume that the sub is at, it goes from 0-40. The blue LED on the front flashes when you change the volume. Long flash = 10, short flash equals 1. Long-Long-Short-Short-Short would mean 23.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Hannzz
    Hannzz Posts: 34
    Volume level means like on scale 1 to 10 when you have knob. I want to run YPAO, and it says turn the volume to half way before run YPAO.
  • Glowrdr
    It goes from 0-40, so turn it to 20 then
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • ken brydson
    ken brydson Posts: 9,047
    Glowrdr wrote: »
    Or 11, hehe:cheesygrin:
