new speakers - rti or tsi
kingbob337
kingbob337 Posts: 5
edited December 2011 in Speakers
I'm swapping out some 10 year old denon speakers that blew I had in my 5.1 setup.
I'm looking at getting the tsi100 and cs10 (at 130 each 260 total) or the rti4 and csi3 combo for the same price for my front and center. I have some t15s that I was going to use for the rear. Should I go with the rti or the tsi? Alternatively I can do the rti6 at 200 and the csi5 at 200 ($400). Is this a substantial improve for an additional 140?
This is primarily for surround sound not music (movies and video games).
Post edited by kingbob337 on
  • larry777
    larry777 Posts: 480
    I would pay the extra $140 for the bigger and better RTi6's and the CSi5 if it was me. A lot better Bang for the Buck than your other options especially for your front 3. Add the RTi4's for rear surrounds at a later date if you decide to go with a 5.1 system. Or buy a set of towers later on for your front L & R and move the RTi6's to the back surrounds. The CSi5 will still match up with the towers where the CSi4 may not do as well.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
    Toolfan66 Posts: 18,187
  • kingbob337
    kingbob337 Posts: 5
    Would the t15s not be suitable rears - or are those just way too subpar. For example, are they going to be drowned out or too washed out.
  • larry777
    larry777 Posts: 480
    You could still use the Ti5's for the rear.....but if you decide to make a change later on, you could go with the RTi line. Matching the front 3 with the same series is more important.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • kingbob337
    kingbob337 Posts: 5
    Cool. I pulled the trigger on the rti6/csi5 combo. If I were to swap out the sub if I decide that the one I have isn't cutting it with these speakers, which one should I go for? Would the psw10 be fine or should I pay the extra 100 for the psi225.
  • larry777
    larry777 Posts: 480
    Someone in another post just reported that the PSW 505 Sub is now on at Newegg for $169. I would pick that one over the other 2. The 505 is a very good sub and is always on sale.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
