External hard drive
simm
Need to purchase an external HD to backup my laptop. Bought a Toshiba Canvio 750 gig last December but it has stopped working after. Anyone have positive experience with any brand in particular? With the recent increases in HD prices I would like to get a 500 gig that will last and replace with a larger one once prices drop again. Thanks.
Post edited by simm on
Seagate, buffalo are both good portable drives but for what you will pay for a 500g you can get a 1.5tb for not a lot more.Speakers: SDA-1C (most all the goodies)
All my external drives are Western Digital. I have 5 that I use to store photos on. A couple are several years old. Not a single failure (yet - I hope this thread doesn't jinx me)."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Have you opened it up? You can probably just replace the drive that's there with the brand of your choice, I prefer Samsung F3's for 3.5 drives (won't be available much longer). I've found all 2.5 drives to be less reliable.
You could also get your own enclosure, these seem to last forever:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817173042
One thing about buying them pre-assembled, you never know what's inside. -
Are you looking at just replacing the drive inside, or the whole unit? I bought an Acomdata 750gig drive for like $100 a few years ago. Opened it up and realized it had a Samsung Spinpoint drive in it. I bought the whole unit cheaper than I could have just got the OEM bare drive. lol65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I am planning to replace the whole unit- truthfully didn't realize that replacing the internal drive was an option. It looks like either Seagate or Western Digital are the way to go. Thanks
I have always gone with Iomega for external hd. Right now all of my back up go to a 1TB Iomega Prestige.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
If you can get by until after the new year, prices are rumored to drop. The flooding in Taiwan caused a shortage and an increase in costs, so if you can, wait a little while.
The cheap part of me wants to wait but if I by some chance my HD crashed I would be looking at months of reburning close to 900 CD's. The cheap part usually wins out on things like this........ -
And this is why I am going to recommend a NAS with RAID instead of an external HDD. If a HDD fails in the NAS (assuming you are using at least RAID 1 or 5) you don't lose your data.
It's all about redundancy with backups, and I recommend at least three copies. With your current solution using a single external drive, you have only two copies--the backup and the original. And like you said, once the external drive goes bad, the only copy you are left with is the original. You could also get more than one external drive and swap them out for consecutive backups, but that solution means that you may lose a period of time of work, depending on which of the drives fails.
Anyway, many ways to skin the cat depending on what your budget is and how critical your data is.
Monster AVL-300, HTS-2500 MKII -
Good advice here. Also, if you went with two separate hard drives, you could simply copy to both at each backup. Either way, I recommend unplugging your backup drive(s) between usage to mitigate the risk of damage from power problems.And this is why I am going to recommend a NAS with RAID instead of an external HDD. If a HDD fails in the NAS (assuming you are using at least RAID 1 or 5) you don't lose your data.
Also, another thing to consider, is just get a couple of inexpensive USB flash drives that are big enough for your really important data. This could even be in addition to your hard drive backups. -
I have the Drobo FS with five 2tb HDs inside. I have it configured with 2 drive redundancy, which yields roughly 5 3/4 TBs of usable space. It goes directly into the back of my iMac via Firewire 800. I had a drive fail about 2 months back and it didn't skip a beat. Got the drive replaced by WD under warranty, hot swapped it and it rebuilt the drive...without skipping a beat. It's pricey though, but for me, the loss of my data would be far worse.
http://www.drobo.com/products/professionals/drobo-fs/index.phpNo excuses! -
I would get an OEM hard drive from somewhere like Newegg that has at least 2 year warranty (retail external hard drives only have 1 year warranty I think). WDC etc. used to have 3 year warranty, but I think they are reducing to 2 years next year ( http://www.zdnet.com/blog/computers/with-hard-drives-in-short-supply-seagate-and-western-digital-slash-warranties/7186 )
Then find a decent enclosure for it, with a fan if you want to have drive extra cool and can tolerate fan noise. -
Remember the old Iomega Zips? I forgot I had one, til now. :redface:
I think I've got one of those laying around somewhere.... 140meg, something like that? -
Yep, I have one tucked away somewhere here, and gave another one to a friend of my with all of my discs.Remember the old Iomega Zips? I forgot I had one, til now. :redface:Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
