Blackstone TL2 Ceiling Mount?
gdpeck
Hi,
Has anyone used wall or ceiling mounts that fit the threaded insert on the TL2 speakers? Currently have the Omnimount 5.0 W/C and the thread on the mount is too small for the speakers. Polk's web site shows that they use a .25x20 threaded insert, the Omnimount website shows 4mm or 5mm, and I don't know how that converts. If you've successfully used the threaded insert, please reply with the brand and model of mounts you are using.
Thanks!
George
Thanks!
George
Post edited by gdpeck on
Hello,
Any of the OmniMount 10.0 brackets will work.
Regards, Ken -
Thanks for the reply. I should have checked the specs before ordering. All is good now.
