Polk Monitor40 vs Klipsch WB-14
gwdgs
Had a chance to listen to these back to back on the same system.
Better looking cabinet - Klipsch - hands down.
Better sounding Polk
So if you are shopping newegg save the $50 a pair and buy the $150 Polk's.
Glad you liked those. But, in fairness, the Klipsch should be compared to the Polk Rti-A1? The Monitor 40s are entry level speakers that list well below the MSRP for the WB-14s.
Personally, I'm not a "horn" man so I've never liked those Klipsch. In fact, I've actually preferred the sound of the TSI-100s to those? But, it's pretty subjective because if you like horns then that's that!
Enjoy!
NE had the M40's at 150 and the WB-14's at $200. I would consider this to be entry level speakers.
If NE/klipsch wants to say the WB-14's are $600 speakers then they are nuts. Wb's would sound like
crap next to B&W 602's. Entry lever or what you can get for under $200 the M40's are the better
deal. -
Thanks for your review/comparison. It's been a while since I compared the sound of Klipsch to Polk, but I do recall preferring the Polks in a direct comparison. However, I've been curious about those wb14s, especially since the price has been as low as $180. Of course the Monitor 40s have dropped as low as $110, so the polks are definitely much less expensive in percentage terms. Can you elaborate on what you like better about the M40s? I'm guessing they have more bass.MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s -
Lower bass with better definition, smoother fuller mid range and classic Polk tweeter.
