Mw 6511's
cwsmith68
What POLKS do these belong in? Say SDA2 on back. Is that right?
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
The 6511 was used in several SDA's.
Here goes:
CRS+ Pin Blade had one on the dimensional side.
SDA2B same as above.
SDA1C used them on the stereo side.
SRS2 Pin Blade stereo side.
SRS2.3 used two on the stereo along with the 6513.
SDA SRS1.2 and 1.2TL used them on the dimensional side. -
Picked up a set for me or whoever mite need em.
Good barter material?Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's -
People have killed for less, so yeah.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
If you, in Any way, try to move those drivers here........you might be killed, raped, eaten & spoken of in an uncomplimentary fashion.:eek: Tip: keep em stashed, at least until you have the magic 100 posts !:biggrin:
Let me guess your PM box is probably full right about now.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
I will abide by the rules. I like it here!Main system:
As for any PM's, not meeee! But tempting.SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
