WIMA MKP4 Capacitors As Power Bypass - Preamp
PreCd
I have a Adcom GFP-565 that I have replaced all the capacitors in save the bypass caps in the power supply stage. Currently they have WIMA 4.7uf 100v MKC caps there for bypass. The WIMA site says the sub for those are WIMA MKPs. Only problem is that the lead spacing is not 30mm but is 37mm for that value of MKP4.
Any suggestions on which cap I should use in the power stage for bypass if I cannot use the MKP4?
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Marantz CD5004
Adcom GFA-545
Just bend the leads in a bit.
