Broken mounting plate
cwsmith68
What glue/epoxy would you guys suggest to use to repair the mounting plate on my RTA 12b's?
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
Mounting plate? Do you mean the binding post plate? If so, I'd probably go with the gorilla super glue.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I'm sorry. I meant tweeter mounting plate on RTA 12B. It was damaged in shipping. It looks to be some kind of composite plastic.Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's -
Maybe a picture of what you're talking about would help.Turntable: Empire 208
Arm: Rega 300
How do I post pics on here?Main system:
Go advanced and click the paper clip (attachments), then upload the pic. It will magically appear. Because it's magic. :cheesygrin:Turntable: Empire 208
Arm: Rega 300
lower right hand corner is the plate and piece is next to it.Main system:
Well, my first choice would probably be old style model glue because that stuff actually fuses the plastic. However, I probably still go with something like the impact-resistant version of gorilla super glue. But that's not much material to work with. I don't have that speaker to be able to see how hard it would be to fashion a new pair of plate out of delrin or something, so maybe someone else will chime in. And you can always give the wanted area a shot and see if someone has one from a pair of 12bs that died or that was parted out.Turntable: Empire 208
Arm: Rega 300
Thanks, Quadzilla.Main system:
