LSI-15 Heaven
ematthews
ematthews Posts: 27
edited December 2011 in 2 Channel Audio
I am about 20 min into hooking up the new LSI-15 speakers. They sound like heaven so far. After the break in I can only see them getting better. Very clear and clean. Nice lows that already keep up with the old Klipsch RF82's that
they are replacing...Love on a Saturday morning
Post edited by ematthews on
    tonyb Posts: 33,065
    Cool, what are you driving those puppies with ? If your not using an amp,keep the volume down until you can grab one. Congrats and welcome btw.
  • ematthews
    ematthews Posts: 27
    HK3490 right now. I have some Emotiva gear on the way next week. The HK3490 runs 150 watts at 4ohms, so I am OK right now.
    EndersShadow Posts: 17,687
    ematthews wrote: »
    Thats the HK I own as well, its pretty good, but I would still watch the wattage on the 15's. Also just as an FYI many here (myself included) have take the stock 8" woofer and replaced it with a Polk d8401 car sub. Its a drop in replacement and it makes the bass tighter and makes it sound better.
    Wait till Crutchfield has them for buy 1 get 1 1/2 off and set :smile:
  • ematthews
    ematthews Posts: 27
    I have that in my plans as well. The stock ones sound good. I read reviews that the lows were the only negative. I like them. No real need for a sub and I got a free one with the purchase....
    ematthews wrote: »
    Given your wattage, I would for sure hook the sub up since the LSi 15's need lots of power down low and you can help take the load off the HK with the sub. Set the gain on the sub at about 70ish....
  • ematthews
    ematthews Posts: 27
    Just hooked up the sub. Set Phase at 180 and vol at 50%. St low pass at LFE setting.
    Sub is the free PSW111
    It does give a nice low feel. A little more full sounding, but a not as tight on double bass lines.
    ematthews wrote: »
    Yeah it will be a bit more muddy, but you can probably turn the volume up louder now and be safe w/ the 15's. Play around with the settings to get it dialed in like you want. I think you may need to set the crossover manually on the sub. Also do the sub crawl so you place it in the perfect position.
    You will find the 15's need about a foot out from the wall and a couple feet on either sides to really dial in the sound, but doing so also kinda hinders the bass. Thats where your sub can help fill in that void.
    Next step you could consider as well is speaker wire. I bought some decent Audioquest speaker wire off a roll at a local custom installer to replace my Monoprice stuff and it did make a difference and cost me like 25 bucks.
    Also use the spikes they sent you if possible, they do make a difference.
  • ematthews
    ematthews Posts: 27
    Funny. I am using the Monoprice wire. 12 gauge I think. I was looking at adding Emotiva's X series speaker wire, but there is so many different opinions on speaker wire..
    ematthews wrote: »
    Yes there are. I would personally suggest posting a wanted AD here and see if anyone has a set of spare MIT AVt cables they bought during the sale they had 6 months ago. Those would be a very good start if not end to your cable needs
  • ematthews
    ematthews Posts: 27
    Oh NO NO NO...My tweeter is starting to get a fuzzy noise on the high notes...Crap. What to do? It's not all the time. It's in and out but seems to be a issue that may get worse. I would hate to think of having to send it back as the box looked like it went through
    war. Would Polk do a replacement part by mail if needed......
    I hope that maybe this will be ironed out the longer I LISTEN
    ematthews wrote: »
    I would disconnect it and call Polk CS
  • ematthews
    ematthews Posts: 27
    Seems it will only do this with one song at certain parts. I have put a few different CD's in and can not duplicate it. Although now it's in my head and making me crazy....How does Polk handle things like this with brand new products? Ot should I try and pack it up and send it back to Amazon for a replacement...I would hate to send it to Amazon as they would be so much trouble shipping. It would suck to send it to Polk too.Maybe they would just do a tweeter replacement
    That is what I would hope and it would be easy to remove it and send it in for an exchange
  • ematthews
    ematthews Posts: 27
    Never mind. It's doing this with other songs now too. It is with Electric guitars and if you slightly touch the silk rib on the tweeter is goes away. It's like a harmonic vibration distortion effect.. Fu@k!!!!!!!!!!
    Call polk customer service on Monday (or today if they are still open) and explain the situation and see what they suggest.
    I have talked to them a couple times and they are very very helpful and nice.
  • ematthews
    ematthews Posts: 27
    I will. I just called Amazon and they said they would be than happy to send out an exchange item. I will just have to wait for another Saturday morning to enjoy the sound of these amazing speakers...
