FLAC end all be all?
dudeinaroom
dudeinaroom Posts: 3,609
edited December 2011 in Music & Movies
for cd quality maybe for HI-res audio uh uh. I recently ripped a mixed DVDA that I have had for a while, but never got the full advantage of hearing. I used DVD audio extractor to rip the disc twice. First time through I did a direct conversion to flac, with no volume leveling or any other type of voodo. Second time I just ripped the mlp files right to the drive. No the difference is not so much in the quality, but in the dynamics. The flac files sound louder with soft passages. And the slow build up in some songs comes on way to fast. The mlp(no conversion straight DVDA files) play the soft stuff nice and soft and the build up is more gradual. Both peak at the same level, I think flac just does not have the same dynamic range as mlp. The best way to describe it would be to say flac has or has near the resolution of DVDA(when encoded from that source), but has the dynamic range of a cd. I can understand the use of flac though for instance George Thorogood's Bad to the Bone in flac format is right around 82M for the file where the original mlp is just over 206M. The differences I experienced are on my laptop (native 24/192) through a B&K pro 10 mc (running passive) into a Parasound HCA 1000A feeding a pair of SDA 2As. When I get a new DVDA/SACD player, I will compare the DVDA to the laptop. As of right now the laptop is the best source I have.
Post edited by dudeinaroom on
  • Fongolio
    Fongolio Posts: 3,516
    FLAC files can run at 24/192 as well. Perhaps you're not ripping the DVDA to flac at high enough resolution to get the full dynamic range of the MLP's. Your smaller size flac files says that I'm likely correct. I've had tremendous success with high resolution flac conversions, very dynamic with huge wide and 3 dimensional soundstages with the right source material.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • dudeinaroom
    The Flac files have a huge soundstage, going back to the source is just more dynamic. The ripper/encoder will only encode up to 24/96. But I should still have the dynamic range, just half the resolution.
  • brgman
    brgman Posts: 2,859
    How does this work when you rip stereo and 6 channel?does it downsize the dvda to 2 channel or what?
    and how could i play back 6 channel from a computer? with a sound card that does that?
    I’M OFFENDED!!!!
