Nice Denon PMA 2000IVR high current integrated amp with remote and phono
geppy1
geppy1 Posts: 3,076
edited December 2011 in For Sale (FS) Classifieds
For sale is a very nice Denon PMA 2000IVR with remote,phono stage, and original box. This is the latest and improved version of the PMA 2000R which was on Stereophie's recommended List for a few years. Uses Ultra High Current MosFets and a true dual mono design. Can drive almost anything and sounds somewhat more open and dynamic sound then the original. One of the few amps I have heard that produces an almost holographic stage with some tracks. Has a very nice phono section and part of the change over the original 2000 is the inclusion of a preamp out and a poweramp direct. This allows you to use it in a HT system if need be. The feel and build quality is off the charts. It weighs 52lbs. It is in beautiful conditon and everything perfectly EXCEPT the right channel on the headphone section does not work and I am not sure why but if you do not use headphones then it does not mater. A repair would be $50 to $75. Otherwise in great shape. Includes Denon PMA2000IVR , original box, power cord, manual, and Denon system remote control (from a diffferent Dennon but works this one) I thought this would be the one but need to get the duaghter a letter jacket for Xmas More info below. Asking $445 Thanks,KG
SORRY FOR THE DOG OR CAT HAIR IN THE PICTURE NEVER SAW IT
Now get the amp and preamp incorporated in one chasis with the Denon PMA-2000 amplifier. With this Denon 2-channel amplifier you can easily plug in your stereo systems into one unit to listen to music with a breathtaking sound. The Ultra-high-current UHC-MOS circuit of this Denon amplifier provides the perfect combination of power and precision. With dual power transformers, this Denon 2-channel amplifier provides 80 watts per channel output. The chassis of this Denon amplifier is divided into six heavily shielded blocks. The Denon PMA-2000 prevents the interference between two channels to give out a clear sound without any humming.
Product Identifiers
Brand Denon
Model PMA-2000 IV R
MPN PMA-2000 IV R
Key Features
Frequency Response 5 Hz - 10 kHz
Number Of Channels 2
Tech Details
Audio SNR 74 dB
RMS Power at 4 Ohms 160 Watt
RMS Power at 8 Ohms 80 Watt
THD (Total Harmonic Distortion) 0.01 %
Remote Control Without Remote Control
Bridgeable Not Bridgeable
Dimensions
Depth 18.75 inch
Height 7.1 inch
Width 17.1 inch
Weight 52 lb
009.jpg 521.8K
006.jpg 505.8K
007.jpg 459.6K
008.jpg 560.3K
Post edited by geppy1 on
