Battery corrosion question....
shawn474
shawn474 Posts: 3,052
edited December 2011 in The Clubhouse
I have a really old set of otoscopes that i want to clean up and give to my brother (he is a physician). I have polished the outside and they look great. All of thr pieces are intact and operational. The case is as well. However, the person who owned them before had them sitting for a very long time with old batteries. They swelled and burst. I have cleaned a lot of it with a toothbrush and mild soap and water. I dont want to damage the internals or ruin the mirrors, but cant get the remaining residue that is caked on. Any suggestions on what i can use? It is greatly appreciated.
Thanks in advance,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Post edited by shawn474 on
  • BeefJerky
    BeefJerky Posts: 1,320
    I would normally use a good electronics cleaning spray...but, I could see it ruining the optics. Honestly, I'm not sure there really is a good approach in this case due to the delicate nature of the instrument.
  • SDA1C
    SDA1C Posts: 2,072
    Use a very weak solution of baking soda and water. Soak a cottonball and let it sit on the affected area.
    Too much **** to list....
    pitdogg2 Posts: 27,048
    SDA1C wrote: »
    i would use distilled water and baking soda.
  • SDA1C
    SDA1C Posts: 2,072
    That brings up an interesting thought as sometimes the lack of nutrient balance in distilled water reacts differently with some powered metals (I am assuming these are aluminum). Especially when bases and acids are involved. It is certainly a good idea over say...chlorinated city water but if you have a clean well I'm not sure I would worry about it.
