Monitor 5 series
deronb1
deronb1 Posts: 5,021
edited December 2011 in Vintage Speakers
Did the Monitor 5s, 5bs, or 5jr use the SL2000 tweeter?
Post edited by deronb1 on
  • bluecomet
    bluecomet Posts: 1,118
    It depends on the model. 5A's use the peerless tweets. Newer models use the SL2000 tweets.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
    heiney9 Posts: 25,509
    Series II use the sl2500.
  • deronb1
    ok, thanks...just thinking keeping the tweets the same as my RTA8ts might be a good idea for HT.
  • skrol
    skrol Posts: 3,464
    The 5A had Peerless or SL-1000, the 5B had SL-2000, and the Monitor 5 series 2 had the SL-2500.
    The Monitor 5Jr (ported) had the SL-2000, 5Jr+ (passive radiator) had the SL-2000 and the 5Jr+ Series 2 (passive radiator) had the SL-2500.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • deronb1
    skrol wrote: »
    Okay, so it sounds like the 5B or 5jr would be a good center match for RTA8Ts.
  • skrol
    skrol Posts: 3,464
    Yep, sounds like a plan.
    Some find the SL-2000 a little harsh while some like them. If you feel the need to tame your RTA8T a little, you can swap the SL-2000 for the RDO-194 which is a silk dome and very pleasing. In this case, you would want to do the same with the 5B or 5Jr or go with the 5 Series 2 or 5Jr+ series 2. If I decide to keep my 5B's I'll be doing the tweeter swap.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Joe08867
    Joe08867 Posts: 3,919
    5b's or Jr's would match fine. The 5jr is an inch narrower than the regular 5's.
