Marantz vs Harman Kardon Receivers
rengnath
Hey everyone,
I'm in the market for a new receiver. Ill be powering my RT1000i speakers, and something small in the rear and a center. All I need is 5.1, and my focus is getting the most power from a 5.1 receiver for under $400. Ill never add an external amp, so pre outs are not a deal breaker. HDMI support is nice, but not necessary.
Im looking at the Harman Kardon AVR 1650 5.1 receiver rated at 95 watts x 5 @ 8 ohms
And another choice is Marantz NR1402 receiver rated at 50 watts x 5 @ 8 ohms
I am also open to going with Yamaha or Denon, but I'm concerned with what true RMS ratings are for all of these receivers. Any help or suggestions on what will give me the best bang for my buck within the named brands?
AVR - Yamaha Aventage RX-A800
Amps - B&K Components ST2140 (for mains) and Parasound HCA-1000A (bi-amping center)
Mains - RT1000i Towers
Center - CS400i
Sub - BIC Acoustech PL200
My neighbors listen to very good music, whether they like it or not :cheesygrin:
Center - CS400i
Post edited by rengnath on
it looks like HK fixed their WPC rating to match other brands. their low end AVR usually around 40-60WPC, now suddenly 90+
As far as sound goes, I like HK; very warm. Denon is very good too. -
You won't find good power brand new for under 400...save up some more...the wattage game is a joke...Manufacture specs are BS, ACD magazine tests are BS...wanna know if it's clean and powerful? Size of transformer, weight of AVR and size of capacitors (measured in uF).
I second this!:arrowu:Make it simple...Make it better! -
I'm going to disagree with this statement based SOLELY on the Carver TFM amps... They do not have massive transformers or weigh very much. -
Maybe someone here can address the eccentric or brilliant design of Carvers? But I'm with LuSh as far as almost all other receivers are concerned. (With the exception of newer Class D designs, of course.)
cnh
Something to do with a variation on the flux capacitor....:cheesygrin:
I just realized this was about AVR's and not dedicated amplifiers.
Disregard my earlier post
Are you open to buying used? If so, i would highly recommend trying to score an Arcam AVR300. It will smoke anything you can buy new for $1500.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
Thanks for the suggestion jayman. I was open to buying used, but I was kind of lery, especially for some of the Yamahas because I read a lot about heat issues causing problems. I was about to buy a Yamaha V2600 on eBay, and I looked at a few Harman Kardons, but couldnt find any great deals. I ended up purchasing a brand new Yamaha RX-A800. I wasn't originally looking at amps, but now I am looking to because it is the only way to get serious power. My dad has suggested a Yamaha M-80, but Im probably looking at an amp closer to 100-200 watts per channel.AVR - Yamaha Aventage RX-A800
Center - CS400i
