Good Monor 40 Subwoofer Match?
dpecota
dpecota Posts: 2
edited December 2011 in Speakers
Hi,
I need advice on speaker choice. I purchased a new plasma 6 months ago to replace my old one. I failed to recognize the lack of analog L/R outputs. The family consensus is that the built in rearward speakers that produce sound in the wrong direction are unbearable and need to be replaced. I bought a set of Polk monitor 40's on impulse intending to open the tv and route the internal speaker connections out. I decided not to do so due to warranty and lack of information regarding the internal amp. I am finally brought into the modern age. So I want to use the 40's as fronts, I have two wireless Advent rears in place from the previous owner of the house. Further impulse I purchased a Polk rm-7 center since it fits nicely in my tv cabinet. The only speaker remaining is a sub.
I was thinking a psw10 or psw505? They are $90 and $180 respectively at Newegg at the moment.
Would the psw10 be sufficient? I usually do not fiddle much and listen to music mixed the same as the original producer intended. My son and I do play video games also.
In line with my bottom feeding I purchased a Sherwood 772 receiver at lunch today since it does two zones: 5.1 and stereo. This what I will use to drive the system.
Thanks,
Dean
Post edited by dpecota on
    tonyb Posts: 33,014
    Go with the 505, a significant step up from the psw 10.
  • Glowrdr
    Glowrdr Posts: 1,103
    The PSW10 would probably be good enough for the specific purpose of enhancing the 40's. Although, I think in the long run you would be much better served buying the 505. Granted, it's twice as much - but you are somewhat future proofing yourself which is a smart buy in my book. There really isn't a much better bang for your buck than the 505.
    You may not want to upgrade now, but think of down the road. What if you come across that deal that you just can't turn down? Much more than the 40's and you might as well use the PSW10 as a doorstop IMHO. Food for thought I guess.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Lietuvis91
    Lietuvis91 Posts: 908
    the psw10 is just terrible in my opinion, step up a notch in quality if you want a smaller sub, or like the others said, get the bigger 12 inch psw505.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • dpecota
    dpecota Posts: 2
    Thanks for the input. A 505 was delivered today. Tomorrow is set up day. I have high hopes. 11 years ago I noticed LR outs and I had two speakers sitting around. That was an eye opener after a life of mono built ins.
