Dared 2000A with phono preamp
brgman
brgman Posts: 2,859
edited December 2011 in 2 Channel Audio
Is anyone using their TT with a 2000A?
If so i am interested in what kind of pre folks are liking with it.
I’M OFFENDED!!!!
  • brgman
    brgman Posts: 2,859
    Interesting.I would have thought tube to tube could be a conflict.
    So which tubes are you really hearing when you use that?
    I’M OFFENDED!!!!
  • inspiredsports
    inspiredsports Posts: 5,502
    Post #4 wenzizi reported as spam for removal
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • george daniel
    george daniel Posts: 12,096
    Hagerman Cornet II,,built by Scomp. Thank you Rich and Carl.
  • CSM41
    CSM41 Posts: 55
    I use a highly modded Cambridge Audio 640P with my Dared. Here is a review and synopsis of the mods / upgrades.
    1. All electrolytic caps were replaced with Panasonic FC's and SU's for the bipolars.
    2. Op amps removed and op amp sockets installed.
    3. Polystyrene caps installed in place of ceramic bypass caps on the op amps.
    4. The two 220pf input caps removed completely.
    5. Optionally input resistors changed to adjust impedance to the cart for best performance.
    It sounds incredible and owns anything at or below 1k that we've put it up against. My analog setup rivals my digital setup with the only variable being the quality of the mastering to determine the better sound. See my sig to see the other parts of the chain.
    #1 Pass F5/Dared Sl2000a/Nola Boxers/Basis Audio 1400/Audio Technica AT33EV Phono Cartridge/Cambridge Audio 640P-Hypno Modded/GF DAC09/CPU
    #2 Cayin A-50T /Hornshoppe Horns/Squeeze Box Touch/Simaudio Moon 100D DAC/Rythmic F12 Servo Sub
