Polk Music speakers
ematthews
ematthews Posts: 27
edited December 2011 in Speakers
Are all of Polk speakers made for home theater first and music second. Which series works best for music that does not have increased high tones out of the tweeter?
Post edited by ematthews on
  • Joe08867
    Joe08867 Posts: 3,919
    The RTi Series is pointed at the theater sound the LSi and LSim Series are more musical.
  • polkfan38
    polkfan38 Posts: 360
    You could probably say the Monitor series (however cheaper) falls in between sound wise. With regards to "warmer", "brighter", "forward", "recessed" descriptive words.
    Things are more like they are now than they ever will be!
  • jps
    jps Posts: 23
    I received two pair of SC60i speakers as a gift. Would these be suitable for HT use? If so, what should I use for the center channel? If these speakers are not the best for HT use, what does anyone recommend? I appreciate the advice.
  • polkfan38
    What are SC60i's? Oh. In-walls.
  • polkfan38
    SC60i's? Put in a 3rd SC for the center if possible.
    F1nut Posts: 51,786
    ematthews wrote: »
    The new LSiM series.
  • thesurfer
    thesurfer Posts: 574
    Even for music, ive never heard anyone saying they would take a pair of bookshelf monitors, over the bookshelf RTiA,s The RtiA,s are just a much higher quality speaker in either application, in my op.
    Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
