Hum from new Aquos
carwashguy
Bought the new Sharp 70' Aquos Quattron. Pleased with most aspects of it so far, with the exception of one glaring problem. It is connected to my HT setup with an HDMI cable and it emits a slight hum through my front channels. It does this even with the TV turned off. As soon as the HDMI is disconnected it disappears. Never had this issue with either of the two previous TV's that have been a part of this setup. Any thoughts? Any help is greatly appreciated, the hum hurts my little OCD soul.
Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Monster HTPS 7000 MKII
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
Panasonic 60 Plasma
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
Panasonic 60 Plasma
Post edited by carwashguy on
Leave everything connected and turn off the amp and see if the hum goes away. I would suspect this to be an amp issue, but if in fact the problem is with the TV try a different HDMI cable. May even try a ferrite core and see if it helps.Shoot the jumper.....................BALLIN.............!!!!!
Try a different HDMI cable first. Are your TV and AVR plugged into the same circuit?
All good ideas. Tried them all, while swapping HDMI finally narrowed it down the the cable box and not the TV. Ran the cable through my power center and out to the box, hum gone. Never had this issue before. Glad it is resolved either way, it was making me insane. Girlfriend said " what hum". Go figure.Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
Panasonic 60 Plasma -
I also have an Aquos, a cable box, and a Denon AVR which is passing video to the TV. No hum issues here. I've read that certain cable boxes are notorious for generating hum. Glad you found the culprit.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
Cable is one of the most common causes of ground loop hum. Usually the cable isn't grounded properly where it enters the house. You can have this happen with or without a cable box.
Sounds like you had a ground loop problem. Sometimes trying a different power outlet will solve the problem, but you already fixed it anyway
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Cable is the cause of the hum in my system (when I have it hooked up), so try to run optical if you have the opportunity to separate the electrical systems.carwashguy wrote: »Girlfriend said " what hum". Go figure.
That sounds about right...
