soundbar dtv and apple tv issue
LTW
New to this. Samsung 50 plasma TV, Polk soundbar 3000 and apple tv (ATV). When using ATV can sound run through soundbar? if so how do I hook it up to do this? TIA. LTW
Failed to mention also using DirectTV. LTW
Not knowing any of those - I'll give you the standard answer that I would expect. Hook the appleTV up to the TV, the run the audio out from the TV (probably an optic connection) and you should be set. Then anything you connect to the TV, will be output to the soundbar.
My appologies if there aren't the proper connections, but the theory should work unless the TV has no sound out.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa"
