Identify these bookshelf speakers!
mugician
mugician Posts: 1
edited December 2011 in Vintage Speakers
My friend gave me this pair of mystery speakers over a year ago. No label on the back. Only today did I take the speaker out to see what it was. Turns out it's Polk. After I've spent months drooling over a pair of new Polk monitors, I find that I've had a pair right under my nose all this time!
Please help me identify! Woofer has a sticker labelled MW7001. Date of assembly 7/2/93.
Specifically looking for nominal impedance rating. I don't have a multimeter.
Thanks!
005.jpg 475.3K
Post edited by mugician on
  • MrGlobe
    MrGlobe Posts: 401
    Would you mind providing some dimensions? I am not familiar enough with previous Polk designs to know off hand what they are. From the pic it would seem they are a medium sized 2 way bookshelf. What size is the woofer?
  • nwohlford
    nwohlford Posts: 700
    These are just called Polk Monitors. I am guessing that they are pretty rare. (I have never seen a pair and there does not seem to be much info on them.) The Mini Monitors that came out around the same time were 8 ohms, so these may be as well.
    Here is another thread about them.
    http://www.polkaudio.com/forums/showthread.php?36290-monitors-(no-number-after-name)
  • nwohlford
  • skrol
    skrol Posts: 3,437
    I have the literature for these speakers and they are listed as "compatible with 8 ohm outputs".
    overall freq resp: 35Hz - 25KHz
    -3dB limits: 55Hz - 23KHz
    Recommended amplification: 20 - 100 watts/ch
    efficiency: 91dB
    Tweeter: 1/2 inch dome
    Woofer: 6.5 inch composite polymer
    Stan
    Main 2ch:
    HT:
    Other stuff:
