Totally Cornfused!
deronb1
deronb1 Posts: 5,021
edited December 2011 in DIY, Mods & Tweaks
I was reading the thread on "spiking" and got intrigued. My RTi12s are on outriggers with rubber feet. They have been sitting on berber carpet, sinking in quite a bit and sounded pretty good with the new amp.
After reading, I placed them on a 20" x 20" x 7/8" inch of solid oak that I took out of our entertainment center that we bought in Germany way back.
Holy Crap! The damn things virtually disappeared. The bass was less pronounced, but tighter, mids seemed to stay about the same and the tweets tamed down.
Can anyone explain to me how this is possible? How did just doing this one little thing give them such a transparent quality?
  • decal
    decal Posts: 3,204
    Maybe that's what you wanted them to do. The human mind is an amazing thing.
  • deronb1
    That is a good point. I am too lazy to change back right now, but I will. I don't think it's psychosomatic, especially in the low end. That is something you can actually feel. Spend a lot of hours in front of these and there is definitely a difference. I'M NOT CRAZY!!!:eek:...... Well, maybe a little.
  • quadzilla
    quadzilla Posts: 1,543
    decal wrote: »
    Yes, especially in its ability to deny that a change might actually result in a desirable outcome.
    @deronb1: It's hard to say what might have brought that about. Possibly it's a placebo effect, but more likely the speaker is better coupled or your alignment may have changed a bit. When using spikes, it's not recommended to use the pads. Those are for placing the speakers on a wood floor. Using the pads prevents the speaker from sitting properly. The spikes won't hurt the carpet, and you want them to penetrate through to the floor beneath.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • deronb1
    I am gonig to get some decent spikes, 1/4 - 20 if I read right. I don't have spikes now, just the fat rubbery-plastic feet on the outriggers. Will compare and check back. Thanks both for your candor.
